Caterpillar Manual:
Hi there, I'm looking for a factory Caterpillar service manual for a 1693TA engine. Mine has an oil leak between the spacer plate and head, (I can see a portion of the gasket missing) and I would like to have a good data source before breaking into it. Engine runs great, but is a little low on oil pressure; at idle only runs about 20psi when hot, but goes right up to 60 plus above idle. I am planning to at least roll lower bearings in while it is out of the chassis. I also can't figger out this "brakesaver" thing without a diagram.
Thanks for any help in advance!!
