Sign in to follow this
Followers 0
cgallamore
Spare Switches
8 posts in this topic
i have 2 unused factory swithches on my dash, one has a picture of a key, the other a battery.
i assume key works with key on, the other all the time.
do they run to a post on the firewall, or will i need to run wires all the way to the switch????????????
Share this post
Link to post
I'm trying to remember on mine I now I wired the under dash lights on the one with the battery. I kinda think my son did the wirering and there was a post in the fuse and breaker panel that turned of and on with the switch. On another post you had mentioned doing an upgrade on your ecm to give you more power at higher elivations just wondering if you've tryed it yet as mine runs terrible when I get into Colorado and Alberta to. Dennis
Share this post
Link to post
Instead of trying to remember what we did 2 yrs ago I should have went and looked at my truck first. Went out and checked mine and there are 2 wires in the fuse panel box on the inside of cab that are labeled. We have wired into one of them to get power with the battery switch. Dennis.
Share this post
Link to post
The battery switch is powered by fuse 61, the stud labeled battery in the dash is powered by fuse 11. The keyed power switch is powered by fuse 30, the stud labeled ignition in the dash is powered by fuse 27.
1 person likes this
Share this post
Link to post
I am never ceased to be AMAZED at the knowledge trapped in the noggin of that rascally wabbit Rhasler! randyp :clap:
Share this post
Link to post
i was going to use one for my rear axle dump valve on the trailer.
the other for all my oversized load becons, all LED less than 10 amp for all.
so i can just hook to the switches, and im good to go????????????
Share this post
Link to post
put on new steer tires, and altinater, bought a cabinet and catwalk and strobe, becons, lightbar, last trip.
when mackpro gets his hands on it i know he is going to put a new air compressor on, and download that program.and i want him to install new jukebox.
im trying to steer clear of him for another month.
Share this post
Link to post
Your installed switch and fuse ratings will tell you this information. However, you cannot go wrong with incorporating a contactor, (relay) in series with your induced loads to take the sudden inrush of current in any electrical system. 10 amperes is not a lot of load but over time the contacts of the switch will oxidize and break down. This would not happen with a contactor coil and larger contacts absorbing this load.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
