There is a mark on the flywheel, then you set the cam in place on 1, then the cam gear, using the silly A-B rod thingy.  Theres more to it, but i havent done one in about 8 years..  you can re-set it. Dont try to run it til its right..
Look at the flywheel if you do that. You may need emeory cloth to uncover the timing mark, that i beleive is a 'zero'... i wish my memory was stronger on this one.
