3 minutes ago, Joey Mack said:
Let me know if you need more part numbers let us know. I may have what you need..
I need a full engine rebuild kit including over size main bearing shells ( not sure of the size yet) plus also might need a turbo
There ya go! Get that puppy pulled down inspect it and decide what parts you need don’t overlook the oil pump it’s likley toast with all the crap gone through it pull the oil cooler down and clean it out as well! Check the main bearings caps ect and the block! Then you can determine what you need totally! Note take lots of pictures! Can save you a lot of headaches! Did confirm the pistons are one piece?
  • Recently Browsing   1 member
