Sign in to follow this
David Smith
Engine Problems
My ENDT 675 is pumping motor oil into the cooling system. What would you check first ? Thanks !!!
Share this post
Link to post
oil cooler {copper tubes wore out in area of steel support cage}
Share this post
Link to post
check the oil cooler for cracks
Share this post
Link to post
You can get a rebuilt oil cooler from your mack dealer, i had the same problem on a 300, there is O rings in there, you get the cooler and housing together just bolt it on. Ron
Share this post
Link to post
Thanks for everyone's help. I will check the oil cooler this week.
Share this post
Link to post
