2007 ctp713 wiring schematic
did you check the main power cable studs on the firewall drivers side?  and you can check them inside behind the dash. the gray wires are grounds... also fuse 71 is for the tranny, it is in the E.P.D.M. behind were the clutch pedal would be.. Jojo
