Grease Fittings
On my old water pump ( Mack ENF510A ) it has a grease cup, on my replacment pump it has a grease zerk.
Should I go back and replace the zerk with the cup or use the zerk?
What would be the advantage / disadvantage of using either one?
David
1948 Mack Pumper
Kinda like a zerk. Fill the cup, give it a twist to force grease into bearings and let it go. On occasion, give cap a twist to force more.
I guess you don't know exactly how much is getting in, guess you have to go on WAG method?
After I had my generator rebuilt I filled both cups twice, on the seconed try I could feel a little back pressure.
I was not sure if that was how it's done,Hope it was enough.
I got the water pump apart today, Took most of the day just to get it apart and cleaned, looks like it will work as is. at least for now. I should get it all back togather, painted and back on the engine Friday. I took a few pictures, I will post them later tonight or in the AM.
It's good to be making progress on the truck again!
DW
1948 Mack Pumper
