Inside Door Handle and Window Crank
Looking for any tips/help on removing the "inside" door handle and window crank on my '63 C85 fire engine.  I searched through the forums here, and pulled up the "escutcheon" as described in other threads here, but couldn't seem to see any pin to take out to remove the handles.
20 minutes ago, ff6cav said:
Inner part, as in inside the door?
On the window and opener handles the round trim ring right next to the door panel is a spring loaded ring you push in to see the pin.    terry:MackLogo:
