Superliner hood hinge assembly
22 hours ago, kscarbel2 said:
When you inquired with Watt's Mack (provider of the BMT website) or at your Mack brand distributor's parts department, with your model and serial number, what did they say?
I haven't had a chance to check with dealer yet. The hinge issue just came to light a couple days ago. I think the problem is more the fiberglass deteriorating where the hood hinges are attached. The metal hinge parts seem ok. Maybe replace "tie rod" ends for good measure. Talked to a friend who has a SL, and he said he had to have his reworked at the hinge connections. Seems a common problem with larger hood.
