Slack adjuster replacement help
Moparmike
Ok guys 2000 Mack rd 688 the slacks on it now just don't adjust anymore time for replacement..ive never replaced 1 before so I really need some guidance..i see these have more parts then my freightliner does....any help would be appreciated
They are auto adjusters or should be.  Not sure of the style of your cam but should be a snap ring and couple of spacers.  Undo the clevis pin and should come off if it's been taken care of.   Might have to use a puller or a hammer to knock it off.
auto adjusters don't need the same maintenance adjustments manuals do usally adjust and keep greased  until it's time for brakes.  The more you mess with them the more issues you will have.
Robert
