firenut Posted April 17, 2017 Share Posted April 17, 2017 Looking for some advice. I just placed the engine and transmission back into the chassis of my L Model Mack Fire Engine. After placement i placed the clutch arm/bracket and I do not know how to set it. It seems like it is not releasing in far enough when I push the pedal. Any advice is appreciated. Quote Link to comment Share on other sites More sharing options...
fxfymn Posted April 18, 2017 Share Posted April 18, 2017 There should be a section on the proper method for adjusting the clutch in the manual you received from the Museum. Quote Money, sex, and fire; everybody thinks everyone else is getting more than they are! Link to comment Share on other sites More sharing options...
firenut Posted April 18, 2017 Author Share Posted April 18, 2017 Unfortunately there is not. The part I am lost on is attaching the arm to the sprocket on the outside of the transmission and "how" to do that. At one time I saw that someone posted the instructions on BMT but I can no longer find it. Quote Link to comment Share on other sites More sharing options...
fxfymn Posted April 19, 2017 Share Posted April 19, 2017 Are you talking about hooking up the clutch fork to the linkage? Quote Money, sex, and fire; everybody thinks everyone else is getting more than they are! Link to comment Share on other sites More sharing options...
firenut Posted April 19, 2017 Author Share Posted April 19, 2017 Yes. and i cant get it to work... Thanks for any help you can provide... Quote Link to comment Share on other sites More sharing options...
fxfymn Posted April 20, 2017 Share Posted April 20, 2017 Not to be Capt. Obvious, but are you sure the fork is engaging the throw out bearing? Have you also made sure the fork is sitting on the pivot point? You should be able to grab the end of the fork and feel if it is trying to move the clutch. The linkage itself is pretty straightforward. Hook the rod to the pedal, hook the linkage from the swivel rod to the fork via the turnbuckle type rod that provides the adjustment. Most clutches work by pulling back on the fork to push the throw out bearing forward. Is the clutch itself an adjustable clutch? If you turned the adjustment the wrong way it will not disengage. Been there done that. Had to pull a transmission twice to figure that dumb ass move out. There should be some type of inspection port on the bell housing that will allow you to see what is going on when the pedal is depressed. It's pretty hard to do, but the throw out bearing might be installed backwards. Is it the correct throw out bearing? Another one of life's lessons learned the hard way. PM me if you want to call me and we can run through it. Sometimes just talking it through provides the "aha" moment you need. Quote Money, sex, and fire; everybody thinks everyone else is getting more than they are! Link to comment Share on other sites More sharing options...
