Loosing Air Pressure
jsanz564
i have an r690 and when the trucks loaded, when you hit the brakes i lose about 60 pounds of pressure, ive replaced one chamber when i thought it was damaged, could it be another chamber? or something else
You only have that massive loss of air pressure when the truck is loaded? How bad does it leak when running empty or "bobtailing". Have you tried airing up the truck to 125 psi, block wheels, have the truck ignition to the on position but without the engine running, releasing parking brake and applying the service brake and listening for the leak.
