dash panel question cx613 vision
i would like to have a place to add a couple aditional switches and gauges, pretty much all my available places are already taken and there is some prime realestate on the dash that is wasted by that little square cubby hole deal. in the center of the dash. do they have a flat panel that can go inplace of the cubby hole factory or aftermarket?
that cubby hole deal is very important. It's where you throw "stuff" you might need some day.
I know it takes up a lot of room. Not in the truck right now, but will check later. You just need about 1/4 inch all around to attach a panel you can make yourself.
Give it some class and make it wood
