need more speed
lowmac
96, so VMAC 1 E7 400, you can get the rpm up a little but youll end up hurting the engine running over 2000 for long periods, change the rears out, you can find a set of takeout carriers for about $1000-$2000 and get whatever gearing you want. if my math is right 120kmh is about 75mph, how fast do you need to run or are you trying to get the rpm down running 120, Im guessing your running 4.42 gears topping out about 75mph, go to 4.17's and youll get about about 80mph or 130kmh and your rpm will drop to about 1850 @120kmh. I am assuming 2000rpm @ 120kmh with a 42" tall tire and a .74 OD.
You can turn off the max rpm limit on newer trucks don't know about vmac 1. I don't know what limit there is to set with vmac 1 it could be roadspeed and it could be engine rpm, either way you'll need to go to Mack or someone with Mack Software to check it and up it.
