E7 460 100th anniversary fuel in my oil
I have e7 460 mack. I have fuel in my oil. A lot of fuel! The popular response from EVERYONE was change your o-rings on your unit pumps. After I changed o-rings on the unit pumps. I drove 200 miles and I have about a gallon of fuel in oil. I took oil pan off and pumped the hand primer to see where it was coming from, but all pressure leaks out when you stop pumping. You would think this would be a pretty big leak and easy to find, but all I can see is a little drip coming down between the end of the steel block and the bottom of the timing cover. I wipe it away and awhile later it is back. You can't see passed the timimg gears so I don't know where it is coming from. Iknow there is a plug in the front of the block ( behind the timing cover ) that is at the end of the fuel resevoir that the unit pumps sit in. Did anyone ever hear of that plug leaking? I think if it is leaking it would be a big leak only when the fuel system is pressurized, like under driving conditions. I checked the fuel transfer pump and its not leaking. I think if I can pressurize the system with air, it will blow the fuel out fast enough so I can see it. Anybody got any good ideas? Anybody ever hear of that plug leaking? This is my first post. Ever.
Had one do the same thing, replaced unit pumper orings, supply pump, still fuel in oil, it ended up being the plug leaking at the front of block at the fuel gallery. Our never did show leaking under pressure, but when engine is running the heat, vibrations caused it to leak more. Good luck
Have had many fuel rail end plug leak. You can usually see a wet spot around edge of front timing cover but not always . Make certain it's not the supply pump shaft seal these fail often also causing fuel in oil, good luck.
I would Drop the pan, apply rail pressure to the fuel system and look up for leaks. Bar the motor over too in case its an EUP leaking at a plunger seal when under lobe pressure from the cam. You will also see if its your timing cover plug leaking into the pan if its dripping from the forward end of the block.
  • 1 month later...
