Stationary variable PTO switch?
Gear variable PTO like the the 6 and 12 speeds
flip the switch and put it in a suitable speed gear to run the PTO and less RPMs
Thats only if the PTO is in the back half of the trans
Thanks for hearing me out.
Yeah if its set up right thats for a pump in gear operation you flip that switch and it disconnects the output shaft so you can put the transmission in gear to get higher pto speeds while sitting still. I have never seen one on a dump truck I can't think of a reason outside of a pump operation you would need it.
