Mid-Liner air system help
RobertRichard
Hi,
i am just a backyard mecanic but this truck is the frist one i see like this when the gouverner cut off , all the air produce by the compressor is blow off by the air dryer exaust not air from the tank just the exesse air produce by the compressor is it normal on a 99 midliner ???
thanks for your help
  • 5 years later...
  • 3 months later...
  • 10 months later...
On 1/14/2013 at 6:30 AM, 39 Baby Mack said:
This probably is normal
We had '86 & '87 CS300's with Knorr air compressors which are not equipped with unloading valves, they govern the pressure
in the brake system by having the excess air exit through the purge valve on the air dryer when the governor cuts out.
Ron
Can I ask where is the governor located on this truck
