Automatic Transmission Fluid in T2090?
mclow
Climbing under my truck yesterday to grease the throwout bearing and noticed "Use automatic transmission fluid for wet clutch", stamped on the side of the case. Should I be running ATF in it? The manual says to put 40 weight in it
Is it a wet clutch?
