unkown air valve
marvgarr
only two ports not a check valve does not hold air in ether direction but seems to limit the air a little when air is put in the direction it was installed does have an arrow took valve apart has big long spring metal disk and in the bottom there is another chamber with a metal ball this valve is in the line from the bake valve to the relay valve for rear brakes this trk does not have front brakes
Hmmmmmmmm.........
I have looked through all of my airbrake catalogs and diagrams, there are not many devices with only two ports that are not check valves!
It could be a ratio valve, which is designed to reduce pressure to the front brakes, if so it should NOT be in the line to the rear brakes.
A relay valve needs full pressure from the pedal...is there a place on it for a wire? It may be a brake light switch?
If it aint either of these you stumped me!
