Dm Wheel/tire Option
bstclee
Just wondering what wheel/tire options I have with my DM886SX (18 front dayton 6 spoke wheels with 12.00R24 tires). I thought it would be nice to have some floaters on the front. I have a couple different manuals that list a optional wheel/tire 14.00R24 but they say it has a 50mph max. How many different parts to change over to put on some 385-425R22.5 instead?
Lee, I've got about 4 sets of 22.5 spoke hubs for 18,000 fronts in my yard.... my guess is that the will fit right on, the only thing I dont know is if the drums will match up. other wise I changed a set over to hub pilot for a customer that wanted aluminum floats. all we need for that was HUBS, BEARINGS, SEALS, AND NEW DRUMS.
Call me I should be in the shop all day...Chris :SMOKIE-LFT::SMOKIE-LFT:
As long as you're changing to the 22.5 hubs, I would suggest using 445/65 R 22.5 floatation tires.
Wider footprint, larger diameter for more ground clearance.
The diameter would more closely match the 12.00 24's on your drives.
