indicators/flashers
hi,i have a 89 r722 model valueliner V8 .can any one help me with a flasher problem?? when i put on r/hand side flasher with motor idling it works perfect but when i put the rev range up it will just stay on, at idle it is putting out 12.5 volts but when revs are up it shows 14 volts. have checked all wire looms for shorts but have not been able to solve problem.has anyone got any suggestions cheers dave.
thanks ,have already done that?? might just have to rewire???!!!!
Ensure your bulb sockets do not have water or corrosion in them, along with wiring terminations. A high resistance connection will fool a mechancal type flasher into not working properly. These are a bi-metal construction and rely upon a give resistance value to "make, and break" the circuit to cause the lamp to flash. With your voltage varying as it does I would be looking at the charging system for evaluation also. The alternator should be outputting near 14.5VDC at engine idle speed if in good shape.
