single drive Posted June 21, 2012 Share Posted June 21, 2012 I am trying to install power steering on my 67 r600 and have come up with a minor obsticle. the air compressor on the motor doesnt have an rear drive, when i pull the rear covor all i see is a bearing. i am wondering if anyone knows what will interchange and if i need an adaptor or not. the motor is an END707 and the number off the original compressor is 303gb561p1. any help is greatly appreciated Quote Link to comment Share on other sites More sharing options...
smorse54 Posted June 24, 2012 Share Posted June 24, 2012 The rear of the crankshaft should have a slot machined across it and drilled and tapped to hold an adapter. The adapter has a male square that fits in the crankshaft and the other end has female spline drive for the p.s. pump.You will also need a new rear cover to bolt the pump to. Phil Young at Gobal can fix you up with the whole works at a great price.His number is 603-239-7008. Good luck, Steve Quote Link to comment Share on other sites More sharing options...
theakerstwo Posted June 24, 2012 Share Posted June 24, 2012 Some of the older bendix compressors will not take the adapter and i cannt remenber if it is only the 500 or it includes the 501 also. Quote glenn akers Link to comment Share on other sites More sharing options...
single drive Posted June 25, 2012 Author Share Posted June 25, 2012 I will have to check it out later in the week when i get home, but my brother says there isnt any place for the drive adaptor. Quote Link to comment Share on other sites More sharing options...
