front brakes
i was wandering if half inch air lines would be better than three eights, any one know if the bigger air line would have more stopping power than the smaller lines. what wound you guys go with. Thanks Ron
Hi Ron, you would not realize any difference. It is air pressure reacting against the diaphram in the brake chambers that relate to breaking force applied to the shoes. A larger air line would only allow more airflow, not pressure.
Thanks Rob i went with the bigger line i didnt know if one stoped any better than the other. i installed a limiting valve and a quickrelease valve on the raiditor mount behind the bumper. Thanks again Ron
You will be happy with the items you have incorporated. I don't like not having front brakes myself and have done exactly as you have in the past.
