Power steering in a 46 EF
I don't know what Mack parts would fit, but both GM and Ford in the late 50's to the early 70's ran a P.S. unit that was attached to the center link. If that would work it would not require the stock box to be changed. Only the P.S. pump, lines and push / pull cylinder to be added.
My B has Mack air assist steering probably adaptable to yours also. Paul
