Sleeper Cab Headliner
I have a 1961 intregal sleeper cab truck with no headliner to go by for a replacement. Once I do the body work , I want to put a headliner in. Has anyone done this before? Any tips would be helpful.
This gets done quite often actually. Most any good automotive upholstery shop will be able to fabricate up a headliner with stiff cardboard (actually oilboard) and tape to hold the shape. This pattern will often be used to manufacture the finished product. 1/8th inch plexiglass is really good to use for a pattern or template if you use a hot air plastic welder. One can really control the application of heat with pinpoint accuracy to bend and form the plastic.
