Steering Wheel
I thought I read in several places on here that an R model steering wheel would fit a B model...
I saw this on EBay, the seller says it was bought for his B , but wouldnt fit, any thoughts?
The mast jacket at the top of the steering column is different between the two series of trucks. The spline count is the same.
Is there an easy way to modify it to work? I assume you are talking about the outer tube... is it to big on the truck? Can you could chuck the wheel up in a lathe and open it up? Or somthing else...
Thanks
Thanks
I suppose you could use a donor mast jacket collar from an R model and modify the B series steering outer tube for it to fit. Never have tried to do it myself. Always rebuilt my own steering wheels for the B series and will be doing an R shortly.
Easiest thing to do is install an aftermarket wheel with adapter although it looks nowhere original.
