Code Scanners
So, last year i bought a code scanner from amazon:
http://www.amazon.com/Autel-MaxiScan-MS300-OBD-II-Scan/dp/B001LHVOVK
It was on sale for 19.99$ or something ike that, and it works well for what i need. I was wondering though, do the electronic mack engines use the same cable interface and protocols to talk to this scanner, or do I need a custom version?
Thanx.
http://www.amazon.co...n/dp/B001LHVOVK
Thanx.
Your Mack would have to have an OBD II port. I don't think any truck makers use OBD II yet but I believe they will under a new federal law. And the better question is, how does one obtain a code scanner for a Mack? Can any Joe plunk down the big bucks and buy one, or do you have to be a certified dealership/garage?
-Thad
The OBDII standard is nearing the end of it's service life and is being replaced with the CAN protocol, (Central Area Network) I believe starting in the 2010 model year. I think all cars produced and sold in North America will need to comply with the new standard by the 2012 model year. It is "transparent" and any scanner that will read the CAN protocol is backwards compatible with the OBDII standard.
Well, that explains why the scanners have gotten so cheap in the last year.
So, what technology do older "electronic" Macks use?
J1708, connecting through either a 6 or 9 pin connector. Starting with 2010 emissions engines the protocol is J1939 (CAN). You can buy an HD scanner from Mac tools, it also available through Mack Trucks, that will read all makes fault codes.
