R600 Info Needed
Gday, firstly does anyone know what the chassis no R611RT3311 would be for, as in what set up it left the factory and what year it would be. definately a flintsone model, am guessing originally it had a C motor/quad set up.
secondly what model number and year gearbox (mack) had a single stick ten speed - is set up in standard 5 pattern with air actuated R - N - L - D. is reverse in all gears, neutral, low and direct? - does that mean no overdrive? not sure but any and all info would be appreciated.
cheers ellis
cheers ellis
A R611RT would have had the ENDT673C,single drive axle,right hand steer.That's a fairly low number,'68 or '69 I'd guess.
If I remember right the ten speed you're refering to is the TRDL107.
thanks for that, yep fella said it was a 67' but is a bogie drive not single. ill look up info on that box no, thanks again.
cheers ellis
Hi Ellis,
R611RT, as Superdog said, ENDT673C, 250BHP, Quad trans and RAD5291 rear axle.
Its been converted to tandem, it was delivered in late 67.
Jeff.
Hi Ellis,
Jeff.
no probs, must have been done early as spoke with second owner from 1974 and was bogie when he bought it, is long chassis so can only think they altered it in some way, looks to be original but who knows. Where do you find any and all info re these models?
thanks again Jeff
