Transmission Swap
rockyvander
Just completed a trans swap from a 6 speed mack with a lo-hole to a T2090 Mack, one problem clutch stays disengaged , I have about 1" of play in pedal but clutch will not disengage , any ideas ?just thought I would see if anyone else has had this problem before I tear back into it would appreciate feed back--thanks --rocky
Welcome to the site
Set the clutch in order according to this buliten, then we'll talk if it dont work!
http://www.bigmacktr...ials&article=43
you may have the incorect arm for the side of the trans
sorry, don't understand low hole
Welcome to the site
2 stick 6 speed TRXL1071 with deep reduction was commonly referred to as "low hole".
