SuperB
Puppy Poster-
Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
Everything posted by SuperB
Thanks for the message. My truck has a TRD72 cast iron trans in it now, it must have been replaced at some point. I just thought I'd see if any aluminum ones were available since that's what it came with.
No, haven't been able to find any yet.
I'm looking for a set of 5 amber glass cab clearance light lenses for a B model. I think they should be numbers LS303 or KD517. Please let me know if you can help. Thanks
I'm looking for wheels for the front of my B model. It originally came with the 10 stud aluminum disc wheels (5 hole). I would consider originals or 22.5 x 8.25 modern wheels. If I put 22.5's on it, I assume I would need stud pilot wheels for on my original hubs, but I'm still coming up to speed on that. Please let me know if you can help or give me any advice. Thanks
B model SG26 steering box lube?
SuperB replied to skydawg's topic in Antique and Classic Mack Trucks General Discussion
I just got a 5 gal pail of 140 GL-1 Chevron (mineral oil) from Reit Lubricants for my steering box and transmission. They're in southeast PA, not sure if they're in NJ. -
Oh no. That'a shame. Hopefully one will turn up. I was happy to see that you're confident I'll find one, Bob. Fingers crossed
Just wondering if anyone would be able to provide any help on where I might find an aluminum case Duplex 10 speed transmission? This would be for a B model. Thanks in advance.
Brian, would you be able to post a picture or 2 of the throttle linkage and spring configuration on your truck? Also, does yours have an oil filter on it for the governor?
I had to remove the injection pump to replace lifter cover gaskets, so I was able to confirm that the oil hose I was questioning does supply the oil to the Woodward governor. The hose connects to the top of the timing gear housing near the engine serial number stamping, and the passage goes through the syncrovance housing and up into the governor. The hose runs across the front of the engine and ends where the primary fuel filter would mount. This is apparently where Mack decided to mount the Woodward oil filter. The other hose runs down to the lower part of the block on the driver's side. I haven't pinpointed that yet, but it would be the oil supply and is currently just connected to the other hose with a tee (my filter was removed and bypassed apparently). I found a Woodward document online that says a minimum 40 micron filter is recommended to be used, and says that many Mack dealers wouldn't have honored the governor warranty if no filter was installed. The filter number above (485GB356) looks like it's the same number as the factory primary fuel filter, so maybe that's what would have been installed? For now, I'm going to install a Moroso remote filter housing and spin-on filter. It's pretty hard to find any info on the hydraulic governor for these, I guess not many were installed by Mack? Seems like most are the mechanical type. Here's a pic of the truck before we left for Macungie last month. Great show!
I think my '65 B61 might have had a governor oil supply filter on it at some point. I believe the 2 oil lines that are still on my truck were for that, but they're just connected together now near the intake manifold. Does anyone have any info on these filters? Is it a good idea to use them even if the truck isn't used every day anymore? The part numbers I have for bracket and filter are 142GB285 and 485GB356. Are photos of these parts available anywhere? Thanks a lot for any help
I had bolted the box back into the truck before I saw your message Mackpro. The only info I got off of it beforehand was "GEMMER" and "7DC06". I used a CR 17231 seal, which seemed to be a good replacement for it. It was only a single lip seal unfortunately, but I think it will last as long as I do
Does anyone have a part number (Mack or aftermarket) for the cross shaft oil seal on a 1965 B61? The gear box number is 20QC319AP1, and this seal is for the shaft where the pitman arm attaches. The seal has an OD of 2.250" and the shaft diameter is 1.750". Any help would be greatly appreciated. Thanks My parts book only has the parts breakdown for a different box, with a seal number of 364SZ66. This seal OD is too big (2.500"). I was able to find a CR seal that should work. 👍
Unfortunately, it looks like I'm still in need of the B model front shock parts. New or good used will work for me. Thanks again for any help.
Thanks for the link. I bought 4 of them, I believe they're the right ones. I really appreciate your help!
I need some link parts (ball joints) for the rotary shocks on the front of a B model. My link rods are 9/16" diameter. I'm interested in new or used parts, or complete shock assemblies. Any help on where I might find parts would also be greatly appreciated. Thanks in advance
Would anyone happen to have any info and/or pics of the plug that covers the approx 5" hole in the lower passenger side of a B model firewall? I "think" it's for the hot air intake to the air cleaner (?), if the truck came with that option. Mine did not have the hot air set-up. If a cover is supposed to be there, I'd also be interested in rounding up the right parts. Any help would be greatly appreciated. Thanks
Thanks guys. Barry was able to help.
I need a 5-6 each of the inner door screws and clips for a B model. 1/4-28 Philips head with the large captured washer for the window mechanism mounting, and the course thread Philips screws and nut/clips for the door panel mounting and lower window travel stop plate. Please let me know if you can help. Thanks
Where does the the rear wiring terminal strip (junction block) mount on the B61 trucks? Mine is under the left rear of the cab, but isn't mounted to the truck. I assume it's supposed to be attached somewhere near the left rear corner of the cab somewhere. Thanks for any help
I need some help with B model battery box configurations. My truck has a 24V starter and a single R model box that's been welded on, and it has two 31 batteries in it. I haven't been able to find any helpful information on how to figure out how my truck would have been originally set-up. I've seen some trucks that have a box on the left side, some on the right, and some look like they have 2 boxes. Would all 24V trucks originally have had 2 boxes? Also, how were the boxes originally mounted on these trucks? The holes in the back of this box would not match up with any original holes in the frame. Were there angle steel brackets? My truck is a '65 B61 tandem with the short wheelbase (146"?) and dual aluminum fuel tanks, and it also has the air tank on the driver's side between the fuel tank and the axle. Thanks for any help
Thanks for the replies. My 711 pan does not have the screen in it, but I believe the picture of the 711 engine in the TS442 manual shows a screen on the bottom of the pan. I just trying to make sure mine has the correct parts on it, and I was a little confused on what was the right set-up on the 711. My fear was that somebody threw this pan on it but left a strainer in there that would need periodic cleaning. I'm not even sure if that could be done, but it sounds like this is the right pan.
Would a mid 60's 711 engine have come with just a plain steel oil pan, or would it have come with the removable sump type pan for strainer cleaning? Thanks in advance for any help
Thanks for the pictures and info Steve, very much appreciated. I'm almost certain now that mine came with the Donaldson type, and it looks like I have one rounded up, with the help of you guys here.
Licensed to kill, sorry, I just saw your message to my wanted ad. So I guess the plastic intake pipe on my truck could be the original one? I just thought I saw aluminum colored pipes on the trucks. It would be good news if I didn't need to round one up. Hopefully I'm not confusing what you're calling the intake. Thanks again I just looked more closely at the connector intake pipe on mine. It's the angled one and apparently the original, so the correct air cleaner for my truck would have a straight pipe on it. I think I understand it better now guys. Thank you
BigMackTrucks.com
Our Vendors and Advertisers
