R 600 Door Locks
I ordered a new set of door locks and ignition tumbler. My door locks were already removed what holds them in. Thanks for all your help.
A clip that slides thru that slot in the door right near where the latch is.
The clip has a hole in the end of it, you slide the clip thru the slot until the hole in the clip lines up with the round hole in the door, then you put the lock cylinder in the hole (make sure you get that square peg into the locking mechanism inside the door as you put the lock cylinder in the hole), then once the lock cylinder is all the way in the hole, you push the clip further in to retain the lock cylinder in the door.
Sometimes they can be a PITA.
