Transmission cooler leak
Go to solution Solved by fjh,
  • Solution
4 hours ago, mcratchet1 said:
Got a 13 mru t310 tranny cooler must have a small leak low on coolant and oil is turning milky after a months use. My question is can I cap of lines and not use cooler? I have same setup in a 07 no cooler on trans.
Yes ! Depending on your work you may not need it!coolant is not good on synchros just do it ! Don’t dead head the lines join them so the oil can circulate!
