Hey all, 2001, E7 Etech 350. For whatever reason this this has started a new issue long crank times. Fuel is clean, all services done. Even did a top set at Mack. Still same issue. Doesn’t matter if you apply pedal or not. Just have to keep it cranking? Any help would be appreciated !!!
https://www.bigmacktrucks.com/topic/75864-e7-etech-long-crank/
Cam and flywheel sensors.. check the condition of the flywheel sensor wires for damage, its quite common. That is the RPM/TDC sensor. That engine will start hard if one of the 2 sensors is failing
https://www.bigmacktrucks.com/topic/75864-e7-etech-long-crank/#findComment-580863
