Ok...  There is a small brass knob on the treadle valve assembly. Has someone shut it off? If its on, look straight down for the VGT air filter. Its a spin on, small like a mower oil filter. Remove the filter and see if air goes through it, there are small air lines that need to be checked down there.  You should see 1/4" lines running straight down the center of the left side of the engine. There is also a celenoid with the filter.  Start simple first by getting air to come out of the line at the turbo. With the key on. Hook an air pump to the truck to keep pressure up.
Joey Mack no air at all until you crank the engine then you have plenty coming out,don’t know if I need to try and mess with that celenoid filter or not that’s a hunk of gold,the truck runs fine just has no boost when you starting from a dead stop.
Sorry bud.  Its almost like throwing high dollar parts at it but without a code reader, and based in the steps you have taken, it may be correct. Did you check the VGT actuator for free movement ? The pin in the yoke can seize.. just remove it and buff it clean, reinstall with anti sieze..
2 hours ago, Jeffrey 34 said:
Joey Mack when you crank the truck up it opens all the way up it just don’t move when you switch the key to on position
Do you have access to compressed air ? Take the line off the actuator and see if you can make it move! As Joey said the pin can seaze on the actuator! Is there any air coming from the stainless line going to the actuator? Sorry I’ve been away since posting this morning! Every start the computer does a sweep check! If it’s not doing that the engine won’t know where to start from!
Yes took the line off and blew air through the actuator and it went all the way and came back that’s working fine ,no air coming out line when you switch truck on until you crank engine up then there’s plenty coming out it pushes actuator rod all the way out when you crank engine it’s just not cycling when you switch truck on ,I have noticed when I’m loaded and pulling hard on engine when I let off accelerator it makes a loud hissing sound but can’t tell where it’s coming from
Try unplugging the egr valve!
