Getting ready to start rebuilding the rear hubs on our B85 and have a couple questions.
First, are both bearings oil bath or is the outer oil bath and inner greased?
Second, if both are oil bath, what’s the purpose of the inside seal between bearings and how does oil get back to the inner bearing?
When I disassembled there appeared to be grease residue on both bearings. Sludge.
Looking for guidance from the masters.
  • Solution
The inner bearings were greased. When I built mine I omitted the center seal and made them both oil bath. Wheel seals today are much better than they were 70 years ago; I like the CR seals (made by SKF) where the rubber lip rotates in the steel housing. They're easy to install and hard to screw up.
going to the CR seals, I've always taken  some gear oil slowly on the inside of the new CR and rotated the seal by hand within it's self. self satisfaction knowing seal has lube. keep in mind this seal was a new item back in "dinosaur days==my time slot" .  not needing stemco seal/ ring installer was a major break through in mechanical terms. earlier topics discussed the two seal wheel set up;;grease inner/ oil outer.
