Hey guys looking for help again on this one.  Dealing with a 2012 granite with the mp7.  The problem started when the dash requested a regen “SOON”. I tried to regen the truck with the dash switch and it would only raise the idle and drop after 3 seconds.  I hooked it up to PTT and discovered spn3675 fmi7 for a fault on the turbo bypass valve.  I diagnosed a faulty valve, replaced it and verified its function then it allowed me to properly start a regen. When it first started a regen the truck blew HEAVY gray smoke for a while, the regen lasted just over an hour when it was interrupted by the low fuel light. I quit that day and tried again today, filled the truck with fuel and tried another regen.  Now the dash says regen “REQUIRED” I allowed it to regen and it lasted over 2.5 hours with no signs of stopping, I stopped the regen because I had to be out of the yard by a certain time. No codes are present, egt’s while regening are around 750° at their highest, differential pressure has now dropped to about .03-.06 but it still blows a little gray smoke while it’s in regen, on jpro it says soot level is at 48% and I can’t get it to drop, also truck is in low derate.  I’m not sure how to proceed, anyone have any tips on what to do or check? I’ll attach a pic of my jpro screen.
https://www.bigmacktrucks.com/topic/74876-2012-mp7-regen-will-never-end/
10 hours ago, steeler said:
Exhaust temp is not high enough, and 260 degrees before cat? That can't be right..
When I have whacky exhaust temps I'm looking at 7th injector, face plugged cat, temp sensors...
I just saw that, goes from 713° EGT to 260° at the DOC inlet, then up to 666° after DOC? Can't help but wonder if it's the temp sensor.
  • 5 months later...
Ă—
Ă—
