2020 LR MP7 Injector Issue
hey guys, have a 2020 LR with an MP7 in it. truck a few weeks ago was filled with DEF fluid in fuel tank. drained tank and had changed the filters, they drove it for about a week with no issues. then it came back with codes for injectors 1, 2 & 3 with open circuit. well traced it back and found pin 1 on injector 2 was shorting out that whole bank. so replaced cylinder 2 injectors, programmed new flow rate no issues and cleared codes. start the truck and now it's setting a P02CF - Cylinder 2 Fuel Injector Offset Learning At Max Limit. checked with cylinder balance test and it's not registering injector 2 and also did a compression test for cylinder 2 and it's showing 11% with tech tool. almost seems like I'm missing something as to programming the new injector and the ECM just isn't registering it, any input or ideas?
All reactions:
11
