1992 Superliner vmac1 code 3-5
Fired up my 92 that pulls my end dump from her winters hibernation.  Last ran in about 3 months ago.  Took it out to top it off and threw a 3-5 code looked it up says >>Timing Actuator Response Improper <<
What is that the ecovance or some sensor? Still runs and drives
Any ideas?
Robert
correct it may have stuck after sitting wouldn't fuss if it has no code now! How old is the oil!  Maybe change the oil !When its working correctly , It gets its orders from the the ecu the timing event marker and the cam sensor according to temp  ect!
Edited by fjh
It has less than 5000 miles on oil, it looks like someone messed with it as the cover leaks and so did the electronic valve.  I took the magnetic apart and resealed it.  I noticed that it had a combo of metric and SAE and a nut as a washer.  I may try and take it apart and reseal it as it seems to be weeping.  Or just run it until it give a fit then replace the whole thing for $789.00
Robert
