Jakes
marvgarr
Have you talked to Barry at Watt's Mack?
They had access to two valve Mack engine brake kits.
If they can't help, I have a brand new (still in the boxes)
TEC kit for the two valve Mack engine that I might consider
selling. It does not fit in my B-67, and I don't have any immediate
use for it.
The actual Jacobs engine brake for these engines has been out
of production for some time. The TEC brake is a direct replacement.
Paul Van Scott
use for it.
Paul Van Scott
Paul why will it not fit you B model is because not enough clearance under the cab? glenn
Glenn -
The B-67 doesn't have the clearance under the firewall.
I could raise the cab an inch or so with spacers - but I don't really
gain that much with an engine brake on this truck anyway.
I do have a new (to me) ETZ-676 (283 hp) that the Jake brake
would be real good on, but I need a truck for the engine to go into.
Thermodyne B63 -
I'll send you a Personal Message right now.
Thanks,
Paul Van Scott
