2004 vision CX613 won't start
theduke24
i have a 2004 mack vision CX613 it turns over but wont start. the 29 pin round plug located a little behind and above the starter had a wire come out. i do not know what wire it hooks too. it has these numbers on it EJ1-10-05 and 64-3-B.can you tell me what wire iy goes too or have a wire diagram for that plug?
That’s gonna be a hard one. 2004 CX’s were an oddball year. They were the first year for the Aset engine and crammed it into the narrow CX frame . They were the only year to use that round connector to connect the engine wiring harness to the chassis/cab harness. Starting in the 2005 the wide fram CXU  ( and CHU) came out and the round connector was replaced by a rectangle connector.
