1994 e7 Valve adjustment
mdphili
the valve set marks are on the fly wheel remove the cover plate on the bottom of the housing  turn the engine clockwise  till you see valve set numbers and a line  place the line dead center in the hole  firing  order 153624  make sure you have overlap on the opposite number cyl in the window 1-6   2-5   3-4    are paired  so if your setting 1 you need over lap or tight valves on 6 and so on   and  usually the valve set  lash    16 intake     24  exhaust but changed  a tad for some years
 check valve cover lash is usually on the tag!
Good luck
Edited by fjh
