Over the last month I have gathered the needed parts for a Wet kit. This last weekend I had the fittings welded to the RH fuel tank and hade the lines made up. I added Hyd fluid tonight and it Works!!! It raised the dump trailer and can operate a low boy. Everything went smooth and had a little luck along the way getting used parts cheep and having the needed parts installed in the trans already. The PTO I have is installed on the 2 stick 6 speed in the lower countershaft so it can operate when the engine is turning instead of using the gear levers to control the speed. next on the list is a barred 5th wheel for frameless dump trailers and a new air slide cyl.
will have some pics tomorrow :thumb:
Trent
