E6 Coolant leak by exhaust manifold
bakelly78
I just went through this there are frost plugs near your exhaust ports they are likely rotten and they seal up just enough when the engine gets hot.It is a easy fix once you remove your manifold.I paid 99 cents a piece for frost plugs.I did this at home if your mechanically inclined its not a bad job to do yourself.
