How downspeeding can destroy your driveline
kscarbel2
 Share
Truck News / October 22, 2014
Downspeeding is great for fuel economy, but it can wreak havoc on an underspec’d driveline.
The trend toward downsped powertrains is unlikely to abate, since a 1% fuel economy gain can be achieved for every 100 rpm slower the engine runs. Several powertrain offerings have come out in recent years that downspeed 200 rpm, providing a 2% fuel savings, which can amount to about $2,200 per truck annually based on US fuel pricing.
But those savings can quickly vanish if your truck is stuck on the side of the road with a mangled driveline.
This is a legitimate concern, according to Mike Schwanzl, senior manager, field sales with Dana. Schwanzle outlined these issues to Truck News during a one-on-one briefing at the American Trucking Associations Management Conference & Exhibition earlier this month.
Downsped powertrains “need faster axle ratios to deliver the same horsepower to the drivline,” Schwanzl explained. “This brings with it the challenges of more torque in the drivetrain. As axle ratios go down numerically, the driveline torque increases.”
Dana claims a downsped engine at cruise speed increases torque in the driveline by 57%. Fortifying the driveline is the only way to protect it against the resulting long-term torque stresses.
Dana has introduced the new Spicer Advantek 40 tandem axle specifically to address this new challenge. It features the industry’s fastest axle ratios of 2.26:1, to handle the higher axle input torques resulting from lower engine rpms at cruise speeds.
The Advantek 40 is a more robust tandem axle than previous designs, which also weighs about 20 lbs lighter. It is coupled with the SPL 350 driveshaft and SPL inter-axle shaft to collectively provide a “fortified” driveline capable of handling the increased torque generated by downsped powertrains, Schwanzl explained. While the Advantek reduces weight by 20 lbs, the SPL 350 driveshaft actually adds 50, for a net loss of 30 lbs. However, Schwanzl pointed out the SPL 350 and SPL 250 have 40% greater torque carrying capability and twice the bearing life over competitive designs. He also noted a lighter-weight steer axle is in the works to gain back some of the weight added by the SPL 350’s heavier-duty u-joint.
Dana claims these are the only driveshafts and inter-axle driveshafts in the market today that can provide a million mile life expectancy in a downsped powertrain environment.
However, beefing up the driveline isn’t the only thing a fleet can do to reduce the risk of damage. Schwazl suggested fleets also torque-limit the engine through a software recalibration. This will minimize the risk of overloading the driveline in lower gears.
“We advocate a combined approach,” he said.
With fleets and OEMs pursuing even greater fuel economy, Schwazl said the trend towards slower-running engines and the higher torque loads they create is here to stay.
“We are hearing the OEMs want to move down towards 900 rpm cruise speeds, so torques will continue to rise,” he said. “We need to anticipate that and engineer solutions now to accommodate more torque in the driveline.”
In the meantime, since the concept of downspeeding is still relatively new, fleets need to ensure they’re spe’ing their drivelines appropriately. Schwazl said Dana saw a spike in equipment failures over the winter – especially in low-speed maneuvers – because customers paired downsped powertrains with traditional drivelines.
Some fleets now stuck with an incompatible system have gone so far as to retrofit their driveline components.
“We have retrofitted a couple of fleets but that’s expensive to do – it’s really not practical,” Schwazl said.
Dana has published a white paper that explores this issue in more detail. It can be found here.
 Share
