The Difference Between B61 And B613
what is the difference between a 61 and a 613? i just bought what the door tag says is a b613 lst. which i think is right do to the aluminum front spring hangers. but the hood says b61. thank you randyjinla
Mainly, the truck was built with a turbocharged engine when it left the factory. The number "3" in "B-613" is the indicator for a turbocharged engine. The "L" means lightweight components, and the "ST" designation is interpreted as a tandem axle semi tractor. A tandem axle straight truck, (or platform) would be a B-613S.
Welcome to the club.
