Randomly my high beams shut off and leave me in the dark. The time that they work and the time that they are off varries from 30 seconds to 4 minutes. They even shut off on smooth roads and while sitting still.
Is there a relay that could be overheating and tripping open?? If so, where would this relay be located?
Anything else I should look for??
Edited by Brandt
https://www.bigmacktrucks.com/topic/35167-another-high-beam-issue/
see your other post http://www.bigmacktrucks.com/index.php?/topic/35166-high-beam-issue-on-r-mdl/
  On 3/27/2014 at 12:46 PM, Dirtymilkman said:
Actually you have a bad breaker for your headlights. Its a one minute fix. I've had that happen a few times.
This is the answer to your problem.
Robert
