1998 ch 355/380 add boost guage
a5redwing
Go to solution Solved by Challenger,
  • Solution
You could just add a manual gauge. You would need a gauge, 1/4" airline and a fitting to put in the intake. Your intake has a small pipe plug ( I think its 1/8 pipe thread). Remove the plug, add a fitting (90 degree, 45, or straight, whichever would work the best for you), install a manual gauge in your dash, and run the airline from the fitting to the gauge. Its that simple.
