Eaton/Fuller 13 speed problem
rondefly
Please help, In the two top positions when I take foot off throttle it disingauges and if I press on the throttle again it re-ingauges, this will happen in high range, could this be a air pressure problem, or something in the trans. also the two top positions don't feel like it goes fully into them when I shift.
Ron Triano this is a 2001 Vision CX613, 007564
Top two positions meaning, 8 hi/lo and 9 hi/lo or just 9 hi/lo? What do you mean disengages? Does the shifter slip out of gear and back into neutral?
sounds like a pressure issue in the back box shift solenoid to me, how do you know its out of gear?
