  On 7/4/2012 at 4:09 PM, Mackman61 said:
I m Wanted to Know if the engine should be hot when i retorque the heads or should i let it cool down to rertorque heads
Under 100 degrees. I say cool.
Should be cool as stated above, back off until lose then re-torque each bolt in proper sequence.
Always was nice to have someone help. He could back off the bolt till lose and you oil under bolt head and washer and torque to 220 lbs. then move onto the
next one.
Don't forget to reset valve clearances.
Ron
