Book On Leader And History Of Mack In Australia
There is a new book just released about the LEADER trucks which were built in Australia during the 70's and 80's. Most of them had a fibreglass cab very similar to the Mack F and FR model day cab. Very strong rumours are that the first Leader was built in the Mack workshop beside the Mack Factory at Brisbane. The book also covers the early days of Mack Trucks in Australia with a lot of great pictures of the early trucks. Check the website below for a preview. Best regards to everybody - Kav from Oz.
www.blueflyer.com.au/leader_trucks.htm
  • 1 year later...
I agree with you, that story is a MUST READ for Aussies !!!!
You are correct, Cyril Anderson was sharp enough to see the diesel age coming in the very early fifties. (As a kid in 1956 I hung out in a yard with four B43's that came from Toowoomba assembly) He put knock-down kit B models together originally at Toowoomba and then down in Brisbane. The Leader truck came out of Cyril's inability to get Mack to agree to produce a "mid range" truck for Aussie conditions and he was losing sales to lighter rigs in the construction and earth-moving arenas. Paradoxically he ended up also building those great big WB (Wde bonnet) models to go up above 130 tonnes.
As I understand it, you are correct, the first Leader was mostly put together in the Brissie factory but was finished off at Toowoomba. The cab was originally a phantom of the F model cab with a bit deeper space. Again it was Cyril's original resistance to fibreglass that shows his flexible mindset when he decided to beat the Fraser Island "rust bug" by going plastic. I believe he went to Melbourne for the early cabs and had some kind of proprietorship over them.
  • 3 months later...
ThermodyneHuey,
G'Day from Dubbo - I haven't been on in some time so I am catching up!
You are correct regarding the cabs from Melbourne - the company Cyril approached was Reinforced Plastics, the same company who did the cabs for the International-based Atkinsons! There is a photo of a RP cabbed Atki in the book!
I wonder if RP is still in business???? Thanks be to Google for the ability to find out!
Joe
  • 1 year later...
ThermodyneHuey,
Joe
Hi Joe,
Have moved out to Watta near Cowra. Pity to be the one to miss the Dubbo truck show. I hope to catch up when I get back from contract in ACT end or 2010.
Been looking for an 8x4 and am offered a MIR-MSR600 but don't know much about them, hopefully somebody can shed some light on their spec.
regards, Huey
Hi Joe,
regards, Huey
Huey,
The only Mack MIR I've ever seent was a MIR785RST - 285hp Maxidyne diesel engine and a twin stick 6 speed gearbox!
Joe
Huey, The only MXX600 was an MBR600, it had a cab similar to a White Compact. The other M's were 700's, the MIR700, this truck used the Brockway low-forward entry cab and the MIR700 which was the most plentiful model, it was the cab with the large windscreens and optional large sliding door windows. Unless you know the model # e.g. MIR785RS or MCR786RST or whatever.
Joe an MIR785 would originally be a 237, an MIR786 would be a 285.
Uncertain about an MSR600, dont know of this model, it could a Renault model.
Hope this info helps
Regards Jeff
